Video Card Monitoring Tool?
  • Video Card Monitoring Tool?
    I have a P4000, P5000, and RTX5000 in the same machine, I'd love to be able to see what they're doing but it seems like task manager even with the new options to view things isn't very good. What do you all recommend for video card monitoring?
    Thoughts appreciated.
    -Joel
    -Joel E
    https://www.biglittlepictures.com
    I use TechPowerUp GPU-Z
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      I use GPU-Z too, but I miss to see the parameters of all cards at the same time (like temp/VRAM/usage). Doe's someone know a tool which do it? Switching from one card to an other is quite slow at GPU-Z too.
        You can also just open 3 copies of gpu-z and change each one to a different card.
          It's a pity that GPU-Z doesn't show the VRAM usage at the task bar. Can someone recommend a tool which could show the memory usage of three GPU at the taskbar?
