The goal is to have a object on the background and render full diffuse but remove background from alpha. I set alpha contribution to -1 for the bg and it shows all white alpha where as it should be just the object that is shown.
I know that I am doing it correctly because when i switch to vray next it works properly. Is there a solution or workaround for vray GPU next? Need this asap.
ps. Attached is what i want. What i get is all white
Thanks
Thanks
