Faster Single GPU
  • #16
    My understanding is, there is an adapter that simply plugs into the motherboard that gets you more 8-pin connectors. The power is there, but I need the adaptor. My fear is buying the wrong part and shorting something out. I emailed another local computer shop, so I'll see if I get a reply from this one. The external eGPU with the PCIe extender sounds like a viable solution. I'll see what cards come out next and maybe I'll buy a couple and drop it in an eGPU enclosure.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #17
      The adapter has to plug into the power supply and provide the needed 8 pin connectors.. (it doesn't make sense that it connects to the board)
      the power supply itself, if modular.. you will see that it has spots for more 8-pin cables
      See the spots at the back here, it should look the same
      I will take a closer look tonight and see what power exactly the T7910 has
      Muhammed Hamed
      V-Ray GPU product specialist
      chaos.com
      • #18
        DELL uses a proprietary unit and I don't see anything like that. My board can have three full-height and full-width cards, however, there are only 2-8 pin power adaptors. Titan needs two. This is my MB
        https://www.dell.com/support/manuals...9cc&lang=en-us
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
        • #19
          DELL assures me that I can have more 8-pin power adaptors, so they plug in somewhere.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #20
            Thanks!
            After some research, it looks like they only have 2 8-pin cables for a reason. This seems to be what is efficient for the 1300 Watts power supply, which is fair enough considering your 2 CPUs
            So my recommendation and the easiest way to get something working. Get this power supply,
            https://www.amazon.com/EVGA-Supernov...s%2C279&sr=8-2
            Then get this tool,
            https://www.amazon.com/24-Pin-PSU-Ju...ower+of+tester
            You will plug it into the 24 pin cable, the widest cable that comes from the power supply (all what it does is tell the power supply that your computer is awake)
            Now you have an infinite supply of 8 pin cables, could do 3 cards if needs be
            Muhammed Hamed
            chaos.com
            • #21
              But they don't tell which cables to get I cannot seem to find that
              Muhammed Hamed
              chaos.com
              • #22
                Yea, they are not in stock and there is no part number. Strange indeed .
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #23
                  Originally posted by Muhammed_Hamed View Post
                  Thanks!
                  Then get this tool,
                  Would this power supply sit outside of my case?
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                  • #24
                    Yes, it will
                    could put it to the side of the case..
                    If you want a cleaner look, then an enclosure for the GPUs/PSU.. which will cost a bit more and take a bit of space.
                    Muhammed Hamed
                    chaos.com
                    • #25
                      or get an eGPU enclosure which includes powersupply, and looks cool on your disk.. you will connect it through a PCIe extender to your PC
                      Sound interesting. Do you have an example link for an enclosure which allow to install two GPU and connect per PCIe?
                      • #26
                        The new cards were announced Tuesday. Any words about them?
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                        • #27
                          https://forums.chaosgroup.com/forum/...0-series-cards
                          Kind Regards,
                          Morne
                          • #28
                            I saw that, thanks!
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #29
                              Is this anything to consider? Or would you be looking at a performance loss?
                              https://www.razer.com/gaming-egpus/R...-01430100-R3U1
                              David Anderson
                              www.DavidAnderson.tv
                              Software:
                              Windows 10 Pro
                              3ds Max 2024.2.1 Update
                              V-Ray GPU 6 Update 2.1
                              Hardware:
                              Puget Systems
                              TRX40 EATX
                              AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
                              2X NVIDIA GeForce RTX 3090
                              128GB RAM
                              • #30
                                My understanding is you'll lose 30% unless you have a scsi card.
                                Bobby Parker
                                phone: 2188206812
                                • Ryzen 9 5900x CPU
                                • ​Windows 11 Pro
