Phoenix FD Fluid Not Rendering in Maya 2020- Vray Default Settings?
  • Phoenix FD Fluid Not Rendering in Maya 2020- Vray Default Settings?
    Hello! I created a scene, dropped in a "tap water solver" and a plane. Did a quick simulation and hit rendering and my fluid is not showing.
    Here is a link to the scene file: https://www.dropbox.com/s/ch5lucc8jb...ting02.mb?dl=0
    There is nothing special about the scene and I have no idea why the fluid is not rendering. I would appreciate any help I can get.
    Do you get any errors or warnings when you start the rendering?
    Can you attach the logs from Phoenix and V-Ray. This article will help to find them >> https://docs.chaosgroup.com/display/...taBug-Logfiles
    What OS you are using?
    No issues with the setup or rendering in a quick test here.
    Tashko Zashev | chaos.com
      I just had to restart Maya for some reason but that fixed it. There were no errors or anything... basically nothing happened when I hit render.
