It has been a while since I've used the GPU version. Now for a new project I am checking to see if I can use the GPU, but I run into 2 problems and hope they are a user error on my side
1) Does Vray GPU support the thickness texture in the EdgesTex map? I need a procedural noice map in the thickness map, but In my tests I am unable to get it working.
2) I use OCIO color space and therefor the VrayBitmap map for all bitmaps. The problem I encounter is that it doesn't support the cropping feature. Is that correct or is it a bug?
