Vray converter
  • Vray converter
    I'm testing Vray gpu, but I have a lot of problem to convert the Corona legacy or corona physical material and also I have some problem when I try to convert a simple materila that have the corona multimap.
    do you have a solutions?
    best,
    Alessandro
    All mentioned issues are being worked on as we speak. Support for Corona Legacy and Physical materials will be implemented in the stable builds soon enough.
      Which Corona build do you have installed by the way?
        Hey, any news on this?
        Trying to convert my Corona scene to Vray and have errors with multimap too. (Latest Corona and Vray installed).
        Here's the screenshot of the error, perhaps there's any easy fix to this I could do myself?
          Yea, that was a sales pitch for V-Ray Next that was a fail. Interopabality between the two isn't as seamless as promised. I use V-Ray Material Converter, which convetrs things without an issue.
          Bobby Parker
          www.bobby-parker.com
          e-mail: info@bobby-parker.com
          phone: 2188206812
          My current hardware setup:
          • Ryzen 9 5900x CPU
          • 128gb Vengeance RGB Pro RAM
          • NVIDIA GeForce RTX 4090 X2
          • ​Windows 11 Pro
            Which one works without any issue? I was looking at V-RayMax Converter PRO​ but i dont see any trial version. Is that the one that works flawless. I have some huge corona scenes that i need to convert to vray fast, Thanks
              V-RayMax Converter Pro, that is the one.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                I saw a workflow where you first use the corona converter to convert coronabitmaps to regular bitmaps, then the vray converter to convert the whole file to vray mats...
                  Thanks a lot glorybound, I will try this plugin instead, hopefully the results are better!
                    Thank you glorybound for the V-RayMax Converter Pro tip! This is really what is needed. I used this tool to convert large and complex scenes from Corona to Vray and was very pleased with the result, unlike the built-in converter.
