3090x2 vs rtx A6000x2
  • 3090x2 vs rtx A6000x2
    I have 2 questions:
    1)witch card is faster render (rtx 3090 or rtx a6000)?
    2)vantage is combining memory of 2 cards (NVlink)? if I put two rtx A6000 48gb I will get 96gb in vantage?
    Hi oleg_svirsky and welcome to the forum,
    Originally posted by oleg_svirsky View Post
    I have 2 questions:
    Both GPUs are using the same GA102 chip, The 3090 is 5 to 10% faster (depending on the model) as it comes with higher boost clocks and power draw
    Chaos Vantage doesn't support memory pooling, you are limited to 24 GB with 2x 3090s.. and 48 GB with 2x A6000s
    Best,
    ​​​​​​​Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      is there is a plan to implement memory pooling?
        npg Could shed light on that topic
        Muhammed Hamed
        chaos.com
          It is on our "TODO" list to try this for Vantage at some point, but it's not going to be near term as we also have other things to do. However, we already have some significant memory optimizations prepared that could help your scenes fit on the gpu. Not sure when this will be released though.
          Nikola Goranov
          Chaos Developer
