vray gpu instance forest pack compiles long time
  • vray gpu instance forest pack compiles long time
    I have done a direct test with redshift and vray gpu. The time to compile if you have lots of instanced objects in forest pack or tyflow particles is insane, it takes certain scenes 1 to 2 minutes to compile while redshift might take 10 seconds. (Just get a detail grass preset from forest pro over a large plane and do the tests your selves)
    Another note, if you proxy a forest object or tyflow in redshift, the compilation time for this particular object is down to 0, it reads directly from disk with while if you proxy a forest object in vray it has to recompile it with no added value. (same for tessellation, redshift bakes the tessellation time if you proxy an object - I think this is a very useful thing if applied to vray proxy)
    Is this something that vray gpu devs will look into ?
    Hey skafimsk and welcome to the forums,
    We are aware of this behavior, I have a few scenes that take a while to compile with FP. The developers will get to this soon
    If possible could you please upload your setup for us, I will add it to the samples that our devs will investigate, plus it will be tested with any fixes from our side in future. Thanks!
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      any news on this subject. Its getting really frustrating working on big or heavy scenes with Vray Gpu. I feel the compile time for geometry keeps getting longer and heavier with forest pack or heavy scatters.
        Hey skafimsk
        This task has our highest priority at the moment, we have multiple developers working on this at the moment(kernel 3 drastically improves time to first pixel in the examples I have)
        Best,
        Muhammed
        Muhammed Hamed
        chaos.com
          I am a Houdini user.
          I have the same problem with Instance on GPU.
          I hope it will be improved.
            Noted, thank you for the feedback sota_oike
            This topic is near the top of our current priority list at the moment
            Best,
            Muhammed
            Muhammed Hamed
            chaos.com
              Hello there,
              On this topic, I noticed the exact same problem, wich is a real pain to work on a day to day basis. Basicaly, I switch to CPU to work, and then siwtch back to GPU for renders.
              Have you any pre-date of release for the kernel 3 you talked about ?
                FranklinTre Hello,
                We are hard at work on getting kernel 3 ready for production, I don't have a timeline when it will be ready
                Time to first pixel with FP is at the top of the current GPU roadmap
                Best,
                Muhammed
                Muhammed Hamed
                chaos.com
                  Muhammed_Hamed would you be able to elaborate on what we can expect from kernel 3 besides FP build times?
                  Are portions of Kernel 3 already implemented?
                    Hello Abraham!
                    Currently only GPU LC is calculated using kernel 3, everything else is done with kernel 2
                    Kernel 3 has many advantages, including support for Out Of Core Texutres/Geometry and faster time to first pixel. It is going to allow us to fix some issues we have in the log, and to implement new features in future.
                    That being said, Kernel 3 is not production ready yet. We are hard at work on getting this done
                    Best,
                    Muhammed
                    Muhammed Hamed
                    chaos.com
                      Originally posted by Muhammed_Hamed View Post
                      Hello Abraham!
                      Best,
                      Muhammed
                      We are looking forward to this, I think this is something that needs to be addressed soon especially since all archviz projects tend to be heavy on scattering/textures/geometry.
                      Any eta for this ?
                        is there an update or nightlies section for this new kernel ?
                          Monthly question: Is the new kernel ready?
                          Software: 3DsMax 2021.3 / 2024.2 | VRay 6 GPU + Chaos Vantage
                          Hardware: i9-13900k | RTX 4090
                          e-mail: imhill820@gmail.com
                            Hey guys,
                            We have multiple developers looking at this now, we need more test scenes at the moment. If you can share some of your scenes with us, please Email me. Thanks in advance muhammed.hamed@chaos.com
                            Best if the scenes are not heavy on shading
                            Best,
                            Muhammed
                            Muhammed Hamed
                            chaos.com
                            • #15
                              Hello Muhammed,
                              Thanks for the updates!
                              Are theire any news on that ? Last update improved drasticaly the Texture "cashing" (don't know how to say that...). But as said before, we run archviz projects, it's insanely heavy on FP and RC objects, xref and so on. Just today, I have a scene that compute in 15 sec in CPU and 2 min in GPU on RTX 3090, just to check a set of trees
                              Can you at least say to us if it's gonna be this semester or next year, so we can know where to invest our money right now? It's a serious issue.
                              Best.
