New render build/node - High-end CPU or GPU(s)
  • New render build/node - High-end CPU or GPU(s)
    Hi there,
    As we are currently considering a new setup for a RENDER PC / NODE, I would like to ask your opinion on the pros and cons of choosing one or more top GPU's vs a high-end CPU. As an example, two options could be:
    A: 16 core Ryzen 9 7950X with 2 x RTX 4090.
    B: 32 core Threadripper Pro 5975WX, GPU to be determined.
    The machine will be used for active work on an on/off basis as well, with software including Rhino, Vray, Autocad and Unreal engine (also looking into 3ds max).
    Things we are considering:
    Active work vs rendering only
    Render time and quality
    Missing functionalities on GPU rendering vs CPU
    4090 x 2 without sli/nvlink?
    Future proofing in general
    Best,
    Arin
    Arin Petersen - cand. arch.
    Laptop: Core i7-9750H - 64 GB Ram -
    DDR4-2667 MHz - 8GB GeForce RTX 2070
    3ds Max 2025 w V-Ray 6 & Forest Pack 9 - Rhino 7
    Autocad Mechanical 2025 - Revit 2025 - Unreal Engine 5.4
    Windows 10 Pro - All up to date.
