I read that there is an issue with the RTX 4090 and V-Ray. Is this true? Other render engines are using 100%, but V-Ray is using 70%
Rtx 4090
Rtx 4090
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
So i dont think ive ever had consistant results of gpu usage, with my 3090 its fluctuates and there doesnt seem to be any consistancy so trying to figure out what is going on is a problem. I literally just videoed rendering in cuda, rtx, progressive, bucket..all were fluctuating. Went back to the same scene and it was hitting near 100 again. Now the scene isnt going above 80%. Something aint right.Last edited by francomanko; 12-09-2023, 03:28 AM.
- Likes 1
There are a lot of issues with Vray GPU.
Vray always uses 2x as much Vram on my 4090 than on my 3090. And it's about 1.5x as fast on the 4090 than the 3090.
The VFB keeps crashing to the point of rendering the program unusable at times - at least in Linux. This usually happens when displays are re-arranged in a multi display config. It's like it tries to place itself in a previous position which it can't and boom. And resetting the position will also cause a crash.This will then require the creation of a new render ROP in Houdini to get it stable again.
When my display isn't connected to gpu0 (the one in the 1st PCIe slot) and to gpu1 (3rd PCIe slot) instead Vray GPU won't render at all.
Textures won't be rendered on GPU when motion blur is switched on, but only sometimes - like on Tuesdays because yesterday was Monday and everything was fine.
Why does it have to re-load the same assets for each frame in a sequence? A waste of time and resources and very annoying with larger textures.
If it does work it's super fast esp with refractions, but sadly the time spent to find hacks around all the issues completely ruin that advantage.
Sorry about the rant but there are other GPU renderers out there that haven't had issues like this for years.
- Likes 1
That isn't good news. I just dropped $1700 on a 4090 to replace my 3090. Is Chaos aware of these things and are they working on it. I mean, hasn't the 4090 been out for a year now? Are you using the recommended driver?Last edited by glorybound; 12-09-2023, 08:31 AM.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Okay, so I am not alone.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostThat isn't good news. I just dropped $1700 on a 4090 to replace my 3090. Is Chaos aware of these things and are they working on it. I mean, hasn't the 4090 been out for a year now? Are you using the recommended driver?
I have the latest version of both Vray and driver.
- Likes 1
It most be a long list . Have you tried Vantage?Bobby Parker
phone: 2188206812
- Windows 11 Pro
I think this needs sorted ASAP. We've all be users along time. Some jumped ship and some stayed. Vray benchmark even runs at 100% yet the render software doesnt. Its rubbish.Taking an old scene with GPU lightcache is so problematic (infinite loop) an issue from many years ago. Change to brute force and you can get it working,although i did notice some textures look like the colours have been crushed (unsure why). Moving around in IPR is so delayed its like it has to reload everything with every camera move.
I tried in Houdini with Karma render engine and its fly's 98%, rotate round, instantly updates and renders clean in like 2 secs.
I bought the card for my main business arch viz with vray and am very dissapointed. Enmesh doesnt even work. Check old posts and states a year ago its in top priority list
Just feels like tools have been added to wow but really they should be alot more stable.
IPR in vray has always crashed IMPO with itoosoft, Corona much more stable
I just hope they can sort it out as other render engines seem to of doneLast edited by leehumphries; 12-09-2023, 09:02 AM.
- Likes 2
Everytime I try GPU it is more trouble than it is worth. I have spent the whole moring trying to render a scene, but everytime I stop the render, MAX's viewport freezes and I have to kill MAX.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I'm glad i got the 4090 though, i just feel that it'll be used for other projects using different software for now. I tested an old interior and it literally hangs and is so noisy when it eventually started working. I gave up in the end.
We'll have to see what reply if any we get from Chaos.
- Likes 1
Hi, thanks for the feedback. Please try to back your negative experiences about V-Ray GPU with examples and details about your workflow. I see some of you have opened separate threads with a bit more details and commenting only one issue at a time. I ask everyone to do that. Please open threads or tickets with your issues, include as much information as you can, scenes, screengrabs, log files, video recordings of your issues and everything will be addressed and fixed. We rely on your help and input to improve but please be constructive about it.
glorybound make sure you are not leaving the "low priority" checkbox enabled when observing the low utilisation that you are talking about.
Originally posted by glorybound View PostOther render engines are using 100%, but V-Ray is using 70%
This is how the usage looks in my testing, there is no difference between a 3090 and 4090 in GPU usage..
First scene on RTX 3090.. Look at GPU1 usage graph, hovering 100% all the way
First Scene on RTX 4090.. Look at GPU3 usage graph, also hovering 100% all the way
Second scene on RTX 3090 hovering 100% all the way
Second scene on RTX 4090 a little lower than 100% because of how fast the 4090 is, still normal and expected behavior
I also tested variety of other production scenes in the same way, there is no usage issues specific to the RTX 4090 or RTX 4080 in V-Ray GPU
I tested on the same machine which has 3x 4090s + 1x 3090, I also tested on different machines with a single GPU, RTX 4080 and RTX 3090 the results are the same
Should you expect 100% usage graph on all scenes in V-Ray GPU?
No, there are multiple factors that could reduce GPU usage- If you have many render elements in your scene, your GPU usage will fluctuate. It will look something like this,
In this case I have +25 render elements in the scene. If you have a few render elements in your, it is normal and expected to have GPU usage and GPU power draw fluctuate. - Another scenario that could reduce your GPU usage, is if you don't have good enough CPU to feed your GPU. Specially for high-end cards like RTX 3090 and RTX 4090, you need at least 6 physical cores per GPU device
- If you have empty space in your rendered frame, like if you have big part of the render as backplate or HDRI or if it all black(empty) this will affect GPU usage
- If you are very close to the VRAM ceiling, you will see a message like Num Samples per thread reduced to xxx mbs, in this case you need to optimize your memory usage
- If you have low thread priroity setting on
- During GPU LC phase, which is handful of seconds usually at the start of the render.. the GPU usage will be 40 to 80%
- During kernel compilation GPU usage will be near zero, it happens only once after you update your driver, or V-Ray version
- Other scenarios for thermal throttling for the CPU or the GPU
- Stick to progressive mode, and use the least amount of render elements whenever possible
- It is quite necessary to have a good CPU with at least 6 physical cores for a high-end GPU
- Avoiding empty space in the rendered frame whenever possible
No..GPU usage will fluctuate in the same way, and it will be lower on using Render elements or having empty space in the frame
For the people with 4090s, here is a test scene please let me know if you are getting different results to what I have
Best,
MuhammedLast edited by Muhammed_Hamed; 13-09-2023, 05:51 AM.
- Likes 5
