Warning : Nun samples per thread reduced to 253363, rendering might be slower
  • #16
    Originally posted by Micha View Post
    Muhammed_Hamed Thank you for your guide on optimizing GPU memory, it is a great help. I have a question about the LC subdivs. When are high subdiv numbers required? I have a complex airplane interior with lots of lights and small windows. Is it helpful to use a high LC subdiv number as a basis for further final calculation to keep the noise low?
    Hi Micha
    I suggest using 3000 LC Subdivs for interior scenes, although you need to keep an eye on GPU memory usage as LC Subdivs have a big impact on that.
    If you render in higher resolution, more than 4k you can go higher than 3000 Subdivs as long as you have GPU memory to work with
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
    • #17
      Chiming in...
      I frequently see that warning pop up, but I'm almost never out of vram. In fact it just came up on a render that's running right now, and I'm only using 7.31GB and 7.96GB of vram on 2x 3090's with NVlink so there should be PLENTY of memory to go around. What else can have an effect on this? Does render resolution play a part? I'm running a panorama at 6,000 x 3,000.
      DESIGNS RENDERED, LLC
      Current Hardware Setup:
      • Ryzen 9 5095x
      • 64 GB DDR RAM
      • 2x Nvidia RTX 3090 Ti w/ NVLINK 48GB vram total
      • #18
        Originally posted by charles_messenger View Post
        Chiming in...
        Please check VRAM usage with Task Manager or GPU-Z not the stats tab, this error only happens when getting close to the GPU memory ceiling
        Maybe GPU LC doesn't have enough samples, GPU memory usage peaks near the start of the rendering when GPU LC get calculated
        Best,
        Muhammed
        Muhammed Hamed
        chaos.com
