Vray GPU - Render Ultra Hight resolution (35k x 24k)
  • Vray GPU - Render Ultra Hight resolution (35k x 24k)
    Hello everyone,
    i'm on 3ds max 2023 and i need to calculate an image of 35400x23600 pixels for a project.
    I've seen that it's possible to go up to 50000x50000 resolution with Vray CPU, but what about Vray GPU?
    Can you tell me the procedure to follow to achieve such a rendering?
    a beautiful day to all
    sincerely​
    This should help for starters.
      Thank you for you reply, I've already read this tutorial, it's only for CPU render, i'am searching exactly the same thing but for GPU render
      In GPU mode, I didn't see any option to override the 3ds max resolution.
      Actually the maximum résolution i can have in GPU mode is 32000 x 32000 pixels (the maximum 3ds max resolution)
        You could export a .vrscene and render it in cmd, where you can set custom resolution width/height. The code should look something like this:
        Code:
        vray.exe -scenefile=<vrscene path> -rtengine=5 -imgwidth=35000 -imgheight=24000
        More info about STD options here.
        The vray.exe file is usually located here:
        Code:
        C:\ProgramData\Autodesk\ApplicationPlugins\VRay3ds Max2023\bin
