Guys...my god, who thought of that interface? Had to trial/error to see what I'm using. Cuda actually always crashes my system, so that was the clue. Says Cuda is default and check is next to it, but I guess if I uncheck I get Cuda, and not RTX
RTX/cuda select on vray 7
Originally posted by Crayox13 View PostCuda actually always crashes my system, so that was the clue.
If yes we will need to setup a remote session to take a look at your setup is possible
Originally posted by Crayox13 View Postbut I guess if I uncheck I get Cuda, and not RTX
Usually the CUDA engine is more stable in IPR, and has better time-to-first-pixel. It uses less GPU memory as well
Best,
Muhammed
Originally posted by Muhammed_Hamed View Post
Usually the CUDA engine is more stable in IPR, and has better time-to-first-pixel. It uses less GPU memory as wellDESIGNS RENDERED, LLC
Current Hardware Setup:- Ryzen 9 5095x
- 64 GB DDR RAM
- 2x Nvidia RTX 3090 Ti w/ NVLINK 48GB vram total
Originally posted by charles_messenger View PostIs there a way to set RTX to the default engine?
- Likes 1
