But when I tried it, every 6th frame was left out.
At first, I thought it was because the computer had no chance to save the renderings to disc within 5 seconds. But the same thing happed with a 10 second rendertime setup. :-/
What is your frame rate? The script is written for 30 fps, if you use anything else, it might break (you will need to adjust the "160" number, which is used to get the current frame).
"Make V-Ray RT Animation Preview" is the improved version of that old script, so use it please. Anyway if you insist on using the old one, make sure your RT is running when you run "rtAnimation()" command.
Peter Matanov Chaos
Hi again..........
Another issue, and this may be down to memory.
Am trying render a preview render in RT, as above.
At 1280 x 720, and it's hits frame 34 and stops.
I have it set to cpu,as I get a unsupported texture error. as gpu.
I have a gtx 470 1.25mb only.
The over all model is quite big, 112 mb, plugins railclone , forest pro, the works.
So I can't do the animation preview , is there a service on line I could use to get the preview out?
