Will be a big problem to add a support for ambient occlusion ? I mean support for AO from VRay GI.
VRay RT and AO
VRay RT and AO
AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
2D | 3D | web | video
jiri.matys@gmail.com
https://gumroad.com/jirimatys
https://www.artstation.com/jiri_matys
https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
https://www.instagram.com/jiri.matys_cgi/
https://www.behance.net/Jiri_Matys
https://cz.linkedin.com/in/jiří-matys-195a41a0Tags: None
Yeah, you right. But sometimes AO produces more depth like images.AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
Yep, however it is a problem to add this to the RT engine. The issue is that AO is multiplied by the GI. For this to be done, one first needs to calculate AO and GI separately, and then multiply the result. However the RT is a path tracer and calculates a single GI ray at a time. So even if this was done, the result would look different than the normal renderer.
To be more precise, in the normal V-Ray, this works as follows:
(result1)=[(gi1+gi2+...+giN)/N]*[(ao1+ao2+...+aoM)/M] where N and M are the number of samples taken for GI and AO respective.
If this is translated to the RT engine, it would look like this:
(result2)=(gi1*ao1+gi2*ao2+...+giK*aoK)/K where K is the number of samples V-Ray RT has traced for a pixel. In the general case, this would be a different color than the first result.
This is just one example of a "cheating" effect that cannot be calculated by a path tracer in the same way as other methods. (Luckily, the rendering equation itself is not one of these)
You can actually notice this in the regular V-Ray as well, in some combinations of settings, where different settings produce different results because of the different number of samples.
VladoI only act like I know everything, Rogers.
