Hi everyone,
I've been experimenting with V Ray RT 3 on the GPU for the potential use in one of my current projects. I want to animate objects in the scene unhidden using the object visibility control under the objects properties menu. This all works fine when using the cpu under V Ray RT but not the GPU. Under the GPU the object are always visible no mater what value the visibility is set to. Is this an known issue with GPU based rendering and is there a work around?
