Okay, don't take the title of this thread to seriously. I don't blame Vray RT or Chaosgroup for this, but I would like to share my experience I just had testing Vray RT on my brand new computer, and hear eventual thought on this.
I was testing GPU rendering (CUDA) in Vray RT when my motherboard completely broke, and I'm curious how this might have happened. Perhaps it was just a coincidence the hardware breakdown happened in the middle of GPU rendering using Vray RT, but there was absolutely nothing going on besides this rendering when the hardware crash occurred. Perhaps it was a bad motherboard specimen, difficult to say. The computer was professionally assembled, and all other components are still working after testing. Only the motherboard died.
Perhaps it's not possible to pinpoint exactly what happened, but anyway, let's start with the relevant components involved:
PSU: EVGA Supernova G2 750W
• Motherboard: X99e-ITX/AC
• GPU: Gigabyte Geforce GTX 1080
• CPU: Intel Core i7-6800K 3,4hgz
• RAM: 1 x Kingston 16GB 2133M DDR4 Fury Black
• Case: Kab Corsair 250D
• Cooling: Corsair Hydro H80, ShadowWings 120mm PWM BL026, (and some additional fans I believe).
• No overclocking or hardware tweaking has been made on the computer.
The thing is that I have been trying out the latest games on the computer with ultra settings. Have run perfectly smooth and stable during many days of extensive gaming without generating significant heat inside the case. No signs of elements that might cause instability. The cooling have handled the load perfectly, and should be able to handle heavy load without problem.
But it only took around one hour of simple GPU rendering in Vray RT before the computer completely shut down, apparently killing the motherboard. I acknowledge that it might just have been a coincidence.
However, I find it reasonable that a GPU rendering process such as Vray RT pushes the performance of the GPU in ways normal game rendering does not. Game graphics are designed to require as little GPU computation as possible, while Vray RT (as I imagine it) is designed to utilize as much performance power as possible for rendering images.
Is it possible that the load of the GTX 1080 can become too much for the motherboard to handle, something that only becomes apparent when the GPU is pushed to its limits? Could my motherboard be too weak to handle such load? Or should there be fail safe limits that kicks in that prevents damage to the card?
On ASRock's product page they brag about this motherboard being "built for content creators", so this motherboard appears to be suitable for heavy graphics related load.
Can it somehow be related to the PSU, yet it affected the motherboard in the end? 750W should be enough. Gigabyte recommends a minimum of 500W for any system using this particular GPU. ASRock's page lists suitable Quadro cards on the product page, they don't differ much from a 1080 card which is tested to consume around 300W at maximum performance according to Tom's Hardware.
But I am no hardware wiz so that's why I'm asking all these questions, in case someone knows.
Again, I don't hold Vray or Chaosgroup responsible in any way. I'm more interested if it's possible to figure out if there is a logical reason for my motherboard's death, or if this was just an obnoxious coincidence from a bad motherboard specimen.
Thanks for any input!
