Lights have lower intesity compared to Adv if Directional parameter is used
  • Lights have lower intesity compared to Adv if Directional parameter is used
    In RT CUDA (set Production renderer) I noticed that the intensity of lights which have a Directional parameter higher than 0.0 render with different intensity compared to Adv. Is this a known issue and is this something that can be fixed to make consistent with Adv? I know it's not the best idea to be switching back and forth between Adv and RT in the middle of a project but in case one must do it it will be a problem since the lighting won't match.
    Please check the following screenshots to see what I mean. All render settings of both Adv and RT CUDA are at their defaults:
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Does it match if you turn up the "max ray intensity" setting in the global options to a higher value?
      No, still doesn't match. I just tried with an Max Ray Intensity of 1000000.0 and still looks 100% the same as when MRI was 20.0.
      Aleksandar Mitov
      96GB DDR5
        I can confirm that something's not right here. Thanks !
        Peter Matanov
        Chaos
