I want to get a more realistic idea of how the lighting will look like when I render my final images with BF+LC in RT. RT IPR always looks darker so I bump up the lights' intensity and when I'm ready to render the final image with BF+LC everything is brighter. What is the correct workflow? Or is this not possible with RT and I should use Adv IPR?
How do I get a better idea of my lighting setup with RT IPR? IPR is darker than final rendering with BF+LC.
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 5090 32GB + GPU Driver 572.83Tags: None
Are you using RT activeshade for the previews and then RT production renderer for the final images?
I find that in RT (production or activeshade) the lighting looks a bit darker in the first few seconds/passes but after that it should be accurate and should be the same whether using activeshade or production and no matter what resolution you're rendering at. If you are swapping between RT and Adv... then thats another story completely.
