Render Element Filtering OFF doesn't work
  • Render Element Filtering OFF doesn't work
    As title says, i need to turn off filtering for zdepth passes and velocity. It's not working in GPU, works normally in CPU. Latest version of Vray GPU Next.
    Is this an easy fix so you guys could update a nightly with it? We're having a big project now that needs this for comp purposes.
    This is supported only with the bucket sampler. We have bucket sampler working in V-Ray GPU nightlies. As with all nightlies - use at your own risk
    Mail to vlado@chaosgroup.com with link to this thread please to check if there is a nightly version that you can test for that.
    Best,
    Blago.
    V-Ray fan.
    Looking busy around GPUs ...
    RTX ON
      Thanks blago, will have a look at it!
      edit: savage309 works with latest nightly, thank you! also hurray for cryptomatte support in gpu!
