Vray Triplanar not working with Vray Normal Map
  • Vray Triplanar not working with Vray Normal Map
    As described in the title.
    I followed this help tidbit at the bottom of the help doc on Triplanar Texture "If you wish to use a VRayNormalMap with VRayTriplanarTex in a material, assign the VRayNormalMap to the VRayTriplanarTex texture node and then use the VRayTriplanarTex in your material. Linking in the other direction is not recommended."
    However, this does not work.
    CGI Artist @ Staud Studios
    My bad - I realise now this tidbit is not talking about Vray GPU
      Hello,
      Sorry about the confusion. There was a bug for V-Ray GPU in this scenario. When the VRayNormalMap was not connected directly to the bump slot of the material the result was wrong.
      We've fixed it for the next service pack and there it won't be a problem.
      Yavor
      Yavor Rubenov
      V-Ray for 3ds Max developer
