Bitmap transforms not applied with Vray normal map node
  • Bitmap transforms not applied with Vray normal map node
    3ds max 2018 / Vray GPU next 4.02.05
    To reproduce :
    _Load normal map
    _rotate it 90° W
    _plug in Vray normal map node
    _plug Vray normal map node in bump slot
    _Render
    During the light cache phase, it looks like transforms are computed correctly but it's not rotated on final render. It works correctly on Vray next adv.
    Should be working, can you please send me the scene?
    Peter Matanov
    Chaos
      Just sent you the link to the scene by mail.
