Dark buckets
  • #31
    After over a month of fighting this (luckily the client is slow to give me feedback), I had to try something else. I launched Corona and it seems to be rendering just fine.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #32
      sad to hear that, but good that you solved it anyway.
      The support guys are also pretty responsive per phone btw - if you can handle the time zone difference!
      Add Your Light LogoCheck out my tutorials, assets, free samples and weekly newsletter:
      www.AddYourLight.com
      Always looking to learn, become better and serve better.
      • #33
        I never thought about calling.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
        • #34
          So, rendering my scene with Corona was successful. With Corona DR, my scene rendered as fast as V-Ray GPU, only it is a clean render. What's up? I couldn't even render these out using V-Ray CPU (3+hours) without cranking setting 2X higher to get a clean render and I was still getting weird artifacts.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #35
            Could you give some specs about what hardware you used for rendering? DR could be anything from two cpus to a huge render farm
            Did you just render the vray scene in Corona or did a conversion and tweaked materials?
            i never used Corona...
            • #36
              I have my main machine and then a Render Pro 2 as my slave, which honestly, isn't much help. I just converted the scene to Corona and hit render, so no extra work there.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
              • #37
                i had the same thing, for me it was the auto exposure / auto white balance that screwed things up between my main machine and DR slave's
