Backburner and distributed rendering
  • Backburner and distributed rendering
    Hi!
    I have vray 3.60.04 3dsmax 2017
    I decided to use vray rt for rendering.
    There are 2 render nodes and 1 workstation.
    i'm trying to send renders to nodes via backburner.
    I selected distributed rendering, added servers.
    Render node which backburner running starts the job but distributed rendering doesn't start.
    I've tested distributed rendering from workstation and everything is fine.
    Please help.
    I assume you have set the distributed render settings on your workstation.
    The settings are saved to a file which you have to transfer manually when using backburner. You have to copy the following file from your workstation to the node, that is distributing the render.
    C:\Users\Yourusername\AppData\Local\Autodesk\3dsMax\2018- 64bit\ENU\en-US\plugcfg\vrayrt_dr.cfg. Copy the file to the exactly same location on the node.
    If you are still experiencing any issues, please contact us at support@chaosgroup.com, or post here in the forums.
    Martin Minev | chaos.com
      Thank you so much.
