forestpack grass rendering some objects blacks
  • forestpack grass rendering some objects blacks
    hi,
    I have a forest pack that renders some geometry black. If I change to cpu, it renders fine.
    I have a vray2side material on it.
    and another question, how it woud be a basic leaf shader? my translucency is grayed out.
    regards,
    leo
    Surrealismo
    https://www.facebook.com/surrrealismo
    Hello! It looks like an issue with Forest Pro in Edge mode with Multi/Sub-Object material which we have logged in our system. If this is not your case, it would be best to send a scene for investigation. Regarding leaf shader you can check this blog post : https://www.chaosgroup.com/blog/port...ay-for-3ds-max . I'm not sure if I understand correctly the issue with translucency being grayed out. Can you post a screenshot of your shader?
    Tanya Todorova
    QA
      thanks! I wrote on itoo telling them your answer.
      I´ve attached the leaf shader. (This is how I setup leaves on vray cpu.)
      Surrealismo
        Hi again,
        VRayMtl's translucency is grayed out, because it is not supported in V-Ray GPU. Regarding the issue with Forest Pro in Edge mode with Multi/Sub-Object material it is logged in our bug-tracking system under VGPU-4110 and I'll post here as soon as we have any progress on this.
        Best,
        Tanya
        Tanya Todorova
        QA
          thank you tanya
          Surrealismo
