I'm wondering why on earth a simple bump map texture cannot work on Vray GPU - I have a stucco bump applied to a wall and all is good with CPU. when switching to GPU, the texture shows simply flat. Am I doing something wrong here? Or is it also a limitation of GPU engine?
Bump Map not working on GPU?
Could you send a simple scene with the the texture you've mentioned to tanya.todorova@chaosgroup.com?Tanya Todorova
QA
