Unhandled exception benchmark
  • Unhandled exception benchmark
    I'm testing a machine with 4x Tesla V100 to be used as a render node but can't finish the GPU benchmark. Latest driver
    Log is attached.
    Edit: Same with driver 442.50
    Could you monitor the temperature of the GPUs and see that everything is stable? Also, could you try running another GPU stress test? Lastly, try installing the recommended driver (441.28 ) and see if that makes any difference.
      I have tried other benchmarks, always some kind of issue...
      I've tried many different drivers but no luck so far.
      I will try a different operating system first to make sure the hardware is good and see if that helps.
        You can try testing your graphic cards separately and see if the issue is with a specific one.
