VRay 5 ACES Chromatic Aberration
  • VRay 5 ACES Chromatic Aberration
    Is it normal while using ACES color management, the glasses materials using chromatic aberration are getting blue ?
    www.salasombath.com
    I presume it is normal since it is expected of ACES to make color manipulations.
      I can understand that while the ACES mode is active the primaries color switch to ACES mode that explain some changes in the colors, but then the problem is that you can't have white glass anymore if you use chromatic aberration, isn't it a bit weird ?
      www.salasombath.com
        We are looking into this, it will be fixed in a patch soon.
          Great ! Thank you
          www.salasombath.com
            Is there some progress on this Dispersion problem ?
            www.salasombath.com
              Yes, we've already made progress. I'll notify you when the fix is implemented in the stable builds.
                The issue should be fixed in the latest stable V-Ray 5 for 3ds max build. Update and try it out.
                  Great !
                  Yes it seems to be fixed on the build vray_adv_50006_max2020_x64_30270.
                  Thank you
                  www.salasombath.com
