GPU Project Settings
  • GPU Project Settings
    When I merge the rendering setting from one project to another, GPU fails 100% of the time. MAX 2021 and V-Ray 5 (however, the same happened in V-Ray 4)
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    How exactly are you merging the render settings?
      Through MAX's merge
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Could you attach the scene you're trying to merge here so we can test with it? I can't seem to reproduce it with the default settings, so there may be some particular parameter/functionality causing it.
          Yes, still happening. This is a different project, but the same problem. I have to reboot max to even use GPU after I merge settings.
          https://drive.google.com/file/d/1LYA...ew?usp=sharing
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            I requested access to the files several times but there wasn't a response. Could you grant it?
              I have been ignoring that request. Can you request it one more time and I'll grant it?
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                I managed to reproduce the issue. Not sure how I did not manage to do it earlier, it seems to happen with a fresh scene as well. Thanks for the report! I've logged it (internal bug-tracker id: VMAX-10204) for developer analysis. For now, as a workaround, use a preset to load the render settings and manually set the other settings.
                  Great, thank you! Any bug-finder reward?
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Yes, the honor of participating in the improvement of V-Ray's quality and the eternal gratitude of the community!
