What gives? All my scenes sit here at compiling geometry for 10-15 minutes. It defeats using GPU rendering. I do have Forest Pack Pro, which can be the issue.
Compiling Geometry
Compiling Geometry
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
- Likes 1
Bump... Has to be forest pack causing this. But it can't be working a intended? I have the same issue where alot of instances via scatter software completly destroys the purpose of GPU rendering with v-ray... Is this something that is being looked into?
- Likes 2
While 10-15 minutes isn't normal, you gotta admit that 3-5 minutes is a standard if you want to use gpu in any heavier archviz scene...My Artstation
Whether it is an advantageous position or a disadvantageous one, the opposite state should be always present to your mind. - Sun Tsu
Yeah, 3-5 minutes is spot on, which is 3-5 minutes too long.
1 PhotoBobby Parker
phone: 2188206812
- Windows 11 Pro
and then 3-5 minutes to cancel the render.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Every time I try to step into GPU I run because of the start and stop times. I am sitting here waiting for about 5 minutes to cancel my render. It just sits there, saying or doing nothing. What is the issue? What can I do to actually be able to use GPU in a normal workflow?Bobby Parker
phone: 2188206812
- Windows 11 Pro
I don't use proxiesBobby Parker
phone: 2188206812
- Windows 11 Pro
I just stopped a rendering, waiting 5 minutes, and deleted some trees. I hit render and I have been waiting at Compiling geometry for 12 minutes.Bobby Parker
phone: 2188206812
- Windows 11 Pro
sounds like its time to switch back to CPU and look at getting a 3990x for your kind of work
vray GPU as bbb3viz said is still experimental and really only for ultra optimized scenes rather than normal tangle of heavy geo and textures that arch vis creates.
Yeah, I just hit render, waiting about 12 minutes to see anything and canceled. I have been waiting for 15 minutes for the cancel. Obviously, I can't work like this. Is Chaos doing any testing with Forest Pack Pro?Bobby Parker
phone: 2188206812
- Windows 11 Pro
