VRayBitmap and named tags
  • VRayBitmap and named tags
    Is this supported in Vray GPU? I try to use user-defined properties in filename.
    I can't get this to work...
    In CPU mode - no problem...
    V-Ray 5, max 2020
    Do you mean the <frameNum> tag? There is an issue with this tag in V-Ray GPU (internal bug-tracker id: VMAX-10451). I'll bump its priority additionally.
      I mean User-Defined Properties. From help https://docs.chaosgroup.com/display/VMAX/VRayBitmap:
      "You can specify node user properties between the < and > brackets. At render time, V-Ray takes the tag name and looks it up in the node's User Defined properties for the shaded object to determine the value of the tag."
        Pardon. From what I tested, it actually works the other way around (works on GPU, not on CPU). What the specific V-Ray version build you're using? Could you attach a simple scene here?
          Simple scene: User Defined tags.zip
          V-Ray 5, hotfix 2 (5.00.05 build 00001)
          Below renders from CPU and GPU respectively.
          Interesting is that during light cache calculation images are visible and then later on disappear...
ID:	1094735Click image for larger version
            You're right, there seems to be an issue with tag values as numbers on GPU. I've logged it (internal bug-tracker id: VMAX-10551) for developer analysis. As a workaround, try setting your object user-properties to "awers=srodek1" (rather than "awers=1") and do the necessary correction in the VRayBitmap location name.
