IPR keeps refreshing in region render
  • IPR keeps refreshing in region render
    It used to be that when I redrew a region render it would just continue rendering progressively, but after the update it restarts the render. Is this a regression? Thanks!
    I've always liked the old behavior with GPU, and wanted it to be available for CPU.
    It seems that it is brokwn now. I hope it is not intended.
    Simply, I love to put pixels together! Sounds easy right : ))
    Sketchbook-1 /Sketchbook-2 / Behance / Facebook
      Is there a nightly I can revert to? I'm working on a long term project that makes this difficult without it. Thanks!
      Also the slider for background disappeared in frame buffer
        I have the same issue and I think/hope it is being looked at. The mouse over render avoids a full refresh and might still be useful. Although I prefer region render as well as it works better with my brain.
          Hi guys,
          Drawing regions should not cause IPR to restart as demonstrated here: http://ftp.chaosgroup.com/support/sc...3_23-25-54.mp4
          The only thing that causes IPR to restart the whole process would be if the Region render is stopped. This is now logged under VMAX-10910 for developer investigation. We will keep you posted, thanks for the understanding and patience!
          Nikoleta Garkova | chaos.com
            Originally posted by nikoleta.garkova View Post
            Hi guys,
            Hi, is there an update on this? Thanks a lot!
              Hey marksmanguy
              This is fixed in our internal builds for GPU; we'll let you know when it's out officially - thanks for the understanding and patience.
                I think that this issue, with the last update from 26/10, came back again. (It was fixed to my enjoyment)
                Hope this can be fixed again. Thanks!
                  Hey Yard2380
                  Discussion about this here, we are aware of this behavior
                  Best,
                  Muhammed
                  Muhammed Hamed
                  V-Ray GPU product specialist
                  chaos.com
                    Hi, this is happening again. Is there a nightly fix for this? Thanks
