Need Assistance with Vray Render Error - "Cancelling GPU rendering!" and more...
  • Need Assistance with Vray Render Error - "Cancelling GPU rendering!" and more...
ID:	1110871Click image for larger version
ID:	1110872Click image for larger version
    ​Hi Everyone
    Lately I have been working on a project of mine.
    Since 2 days ago I started to get the same 3 errors in my projects which I attached as screenshots.
    I tried many methods, including re - installing Vray, Checked my Driver version of the GPU, changed Vray render Options...
    Nothing worked for me...
    I also checked other projects and the issue seems to happen there too, which it did not before...
    **Attached the download link of the the project in case of need.
    Can I get any assistance?
    Thanks!
    I am receving similar error "Could not allocate device frame buffer...:" error since update to VRay 5 (Maya 2020) in almost every scene.
    My Artstation
    Whether it is an advantageous position or a disadvantageous one, the opposite state should be always present to your mind. -
    Sun Tsu
      You may be running out of VRAM. Check your GPU memory usage through a third-party software such as GPU-Z and see if that is indeed the case. If so, you would need to optimize your scene (lowering texture resolution, lower quality displacements, etc.).
        This seems like it is a VRAM issue,
        I Optimized all the textures, seems to work for now, if something will happen again I will update, Thanks for the Assist!
