I can't seem to be able to stop IPR rendering if Distributed Rendering and Real Zoom in the VFB window is turned on. I suppose this is a bug?
Can't stop IPR if Distributed Rendering and Real Zoom are turned on
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 5090 32GB + GPU Driver 572.83Tags: None
Hi Alex,
Thanks - this is a known issue and is logged into our system under VMAX-10999; I'll bump its priority additionally. This is just a UI issue (the render does stop once you abort it); http://ftp.chaosgroup.com/support/sc...9_11-02-38.mp4
I'll let you know when there are any updates on the matter.Nikoleta Garkova | chaos.com
Thanks, Nikoleta! Are they any workarounds that avoid closing Max if I want to render again when this bug happens? I tried the "Start IPR" button in Vray's Render settings tab, but it doesn't seem to do anything if Vray locks like this. In fact, it starts using my GPU resources as if it is rendering, but nothing happens in the VFB window. Then I tried disabling the DR rendering before clicking on the "Start IPR" in the Render settings tab, but that leads to Max crashing. Same crash happens if I disable DR and then start a production render (F9). So it seems the only thing I can do if this bug happens is to kill the Max process in Task Manager and restart Max if I want to render again, or? Thanks in advance!Aleksandar Mitov
96GB DDR5
Using this procedure seems to be working, thanks. I'm not sure why, but I was getting crashes when I tried this earlier. Unfortunately, this workaround doesn't seem to completely fix things. Real Zoom stops working at all and I need to restart Max to use this feature again. Anyways, I'll try to be more alert and avoid using DR with IPR until this is fixed. Thanks again for the help on this!Aleksandar Mitov
96GB DDR5
