Missing VRayGPUViewportIPR VRay (for 3DS Max 2022)
Silly question, but have you made sure your current renderer is set to V-Ray GPU? Have you tried hitting the 'V-Ray menu registration' button on the V-Ray toolbar?
You could also try a couple of other things - manually add the option from the Customize UI option > Menus - use the Action list on the left.
Or, delete/rename the ENU folder (this will restore 3ds max settings to their defaults) to see if that changes anything - C:\Users\USER\AppData\Local\Autodesk\3dsMax\2022 - 64bit\ENU
