VRayOCIO texture doesnt work
  • VRayOCIO texture doesnt work
    VRayOCIO texture in this setup has no effect:
    In CPU mode everything is OK.
    BTW
    VRayOCIO texture doesnt work with VRayMultiSubTex. This setup doesn't work:
Name:	ocio multisub.jpg
    Huh, it works for the preview only. Odd. I'll investigate further, however, you can set the RGB Primaries of the VRayColor directly to ACES, so there isn't really a necessity for conversion.
      There is an issue with this on the current stable builds, it doesn't give the same values as VrayOCIO node
      It is very important, any backplate images or logos will need to be imported in as "Output-sRGB" this is only possible with VrayOCIO node
      Muhammed Hamed
      V-Ray GPU product specialist
      chaos.com
        Right. Just so you know, I've logged the issue (internal bug-tracker id: VGPU-5557) for developer investigation.
          Thank you Aleksander
          Muhammed Hamed
          chaos.com
