Vray GPU bug - Mat ID in Multimatte doesnt work in a Vray Blend Material
  • Vray GPU bug - Mat ID in Multimatte doesnt work in a Vray Blend Material
    As per title - Mat ID in Multimatte doesnt seem to work in a Vray Blend Material.
    Trying generate a matte from a b+w image and gradient ramp insuide a vray comptex that sits in the blend map slot.
    This works on Vray CPU
    every single job I do throws up a basic roadblock on vray GPU, kind of a running joke now.
    Thanks for the report. I've logged the issue (internal bug-tracker id: VGPU-5561) for developer investigation.
      Thanks, small bug but a annoyion one. ended up back on CPU for this shot
        Any update on the issue ?
        It seems to be still there in 52023 and we use a lot of blend material and ID passes
        Thanks,
        Best
          It is related to the Render Elements not working behind glass, I'm not sure if this is easier to fix or not. I left a note for our devs
          Both requests are high priority for some time now
          Best,
          Muhammed
          Muhammed Hamed
          V-Ray GPU product specialist
          chaos.com
