VRayEdgesTex on GPU problem
  • VRayEdgesTex on GPU problem
    ​Hi all!
    I'm encountering some issue with the VRayEdgesTex material on a very simple object.
    The attached image is self-explanatory.
    I'm not sure why in the GPU render I see also the triangle edges of the mesh object instead of only the poly edges...
    Any advice?
    Thank you!!!
    Ale
    Vray Next for 3dsmax - Certified Professional
    Is the object a proxy? There used to be an issue with the "Show subtriangles" option being always active with Proxies and GPU. It was fixed in V-Ray 5.
      No, the object is a poly inside the scene.
      Sorry, I forgot to tell you this is in 3dsmax 2022 latest release, and Vray 5 latest release.
      Thanks!
      Ale
        Could you attach the scene here or send it via the contact form so we can take a look? For the latter, mention me and include a link to this thread.
