Fur Material renders black when using RTX and CUDA, but works with CPU
  • Fur Material renders black when using RTX and CUDA, but works with CPU
    Hello,
    I am having an issue with rendering fur (as grass). For some reason, it renders black when I apply a material to it and using RTX or CUDA. But when I use the CPU, it renders just fine. Is there a reason for that? Attaching two images, one with RTX and one with CPU rendering.
    Hi ous_abouras
    What material did you use to shade the grass here?
    What DCC and V-Ray version?
    If it is using the old translucency, it will render black. You need V-Ray 5 update 2 for this to work, and you will go manually and swap translucency to the new SSS models
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      I used the normal Grass materials, which I don't believe is translucent. I even tried a making regular generic material, and changed it to green and it was not working. I also am using the VRay 5.20.02 update for that. What did you mean by DCC tho?
        Hey ous_abouras and sorry for the late reply
        DCC is your host DCC like SketchUp or 3Ds Max. Please use the contact form to submit this scene, I will take a look at your setup
        Best,
        Muhammed
        Muhammed Hamed
        chaos.com
