Big problem: parts of a complex scene are not rendered (V-Ray for Rhino)
  • Big problem: parts of a complex scene are not rendered (V-Ray for Rhino)
    I have complex scene and I hide unseen objects to keep the memory usage low. But now my client want to get panorama views and I need to show all objects at the same time. I did a first test and enabled all objects. But now objects of the scene are invisible at the rendering, it looks like random objects are not loaded. What can I do? In CPU mode all objects are visible and the scene looks good.
    -Micha
Name:	Screen Shot 12-17-21 at 12.04 PM.JPG
    I found that it works in RTX mode and is using only ~4GB at my render-only GPU. So, It's not a question of the memory. I will send a bug report per email. ( #16268 )
      It is an odd behavior thanks for the report. Did you send the scene already?
      Best,
      Muhammed
      Muhammed Hamed
      V-Ray GPU product specialist
      chaos.com
        Yes, there is a download link at the report email.
          Dear Micha, hello.
          Your scene is successfully delivered.
          I confirm that there is a difference in CUDA - CPU/RTX results.
          Will discuss with Muhammed and the dedicated teams and keep you up to date what is happening.
          Thank you for reporting.
          Please confirm with which V-Ray version was the project started or are there any objects that may come from projects where old V-Ray versions are used.
          This is important to exclude Migration issues.
          TS
          Tsvetomira Girginova | chaos.com
          3D Support (AEC,HOU,C4D) Team Lead | contact us
            The project was started in may/june per Rhino7|VfR5. I checked the material list now and found some materials which are looking like VfR4 materials exported from the disk. (.Stoff.xx)
            I got all 3D-models from my client, but he doesn't use V-Ray.
              Thanks, Micha!
              Logged with VRW-3519 number in our system.
              Will notify you ASAP by any news.
