I have a scene that hangs up on "Building GPU Light Cache" (both IPR and Render), but if I switch the Engine Type to CUDA and uncheck the CPU box, there are no issues. Why would this be the case? Also, I was under the impression that the difference between RTX/CUDA was that CUDA offers a hybrid approach for both CPU and GPU, whereas RTX is GPU only. A friend says that RTX renders much faster than CUDA, even with the CPU box unchecked. Thoughts?
RTX vs CUDA Engine Type Issue (bug?)
www.DavidAnderson.tv
Software:
Windows 10 Pro
3ds Max 2023.3 Update
V-Ray GPU 6 Update 1
Hardware:
Puget Systems TRX40 EATX
AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
2X NVIDIA GeForce RTX 3090
128GB RAMTags: None
Hi Streetwise , thanks for the report
Originally posted by Streetwise View PostI have a scene that hangs up on "Building GPU Light Cache" (both IPR and Render), but if I switch the Engine Type to CUDA and uncheck the CPU box, there are no issues. Why would this be the case?
What V-Ray Build and what driver?
Originally posted by Streetwise View PostAlso, I was under the impression that the difference between RTX/CUDA was that CUDA offers a hybrid approach for both CPU and GPU, whereas RTX is GPU only. A friend says that RTX renders much faster than CUDA, even with the CPU box unchecked. Thoughts?
Some scenes will render faster with RTX mode, if you have a lot of grass or hair for example this speed boost can be significant. Other than that, Cuda is very close/similar in performance
Best,
Muhammed
Muhammed_Hamed Could I DM you with a link to the scene? A simplified version seems to work okay. It's when there are all of the assets that it hangs up. So it's a fairly large scene.
The team member that is having the issue is on V-Ray 5 Update 2.3 and a driver of 471.68. I'm personally on 512.15 and Update 2.3 and am not having the same issue, although it does take a bit to calculate. Is there a particular driver that you recommend as stable? Maybe that's our issue.
Thanks
David Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
Hey Streetwise
Sorry for the delay, we upgraded the recommended driver to 512.59 it works very well with V-Ray GPU
You can Email me the scene muhammed.hamed@chaos.com I will take a look and report back
Yeah, the new drivers fix some issues related to Geometry artifacts. This fix is on 495.xx drivers and later
This doesn't affect Cuda mode
Let me know if using the new drivers solves the issue
Best,
Muhammed
