Patches with VrayEdgesTex where surfaces meet
  • Patches with VrayEdgesTex where surfaces meet
    I have patches forming with VrayEdgesTex where surfaces meet. The CPU engine renders it perfectly fine. This will probably be the last time I use Vray GPU for any production work. I just can't handle all the bugs anymore, to be brutally honest. I don't care if it's 10x faster than CPU when I constantly have to deal with problems like these on a daily basis...
ID:	1150848Click image for larger version
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Hi it could be something related to the geometry. Are you using the VRayEdgesTex for chamfering the edge? Could you share a bit more details and also the scene if possible? You can post the scene here or trough the support contact form..
    Vladimir Krastev | chaos.com
      Yes, I'm using edgestex to chamfer the edges. I've submitted a ticket with number 42649 containing a download link for the scene. I remember reporting this issue with VrayEdgesTex a year ago.
      Aleksandar Mitov
      96GB DDR5
        Ok Alex_M I will check your ticket and scene. There is and issue with a similar problem in our system. Let me check the scene and I will get back to you.
          I just suffered 4 hours to make just a single render... I'm really tired of vray gpu 5 believe just because the 2d displaccement i already wrote in vray gpu for sketchup...
          I hate vray gpu!!! So unstable!!!
            Hi according to my tests with your scene these artefacts are a result of the combination of VRayEdgesTex and poor geometry topology in V-Ray GPU. They are present with or without the "same object only" option.
              Thanks for reviewing the problem. How can I prevent this? I recreated the model with clean quad geometry and I am still unable to get clean edges (see below). Attached below is also the new geometry if you would like to test it.
              Click image for larger version  Name:	vray_GPU_edgestex_bug3.jpg Views:	0 Size:	64.3 KB ID:	1151202Click image for larger version  Name:	vray_GPU_edgestex_bug4.jpg Views:	0 Size:	386.4 KB ID:	1151203
              Aleksandar Mitov
              96GB DDR5
                Fstorm doesn't seem to have such issues even with the messy triangulated CAD geometry:
                Aleksandar Mitov
                96GB DDR5
                  Hi I tweaked the model a bit and managed to clear out the outer edge. The inner edge started showing the same issue though.
                  I will collect all the info and report this for improvement. Thanks for the report.
                    Does the VrayEdgesTex in MAX = Round edges in Maya? (the extra attribute in a Vray material or shape node) The only Vray Edges texture I see in maya renders a wireframe thingo.
                    Website
                    https://mangobeard.com/
                    Behance
                    https://www.behance.net/seandunderdale
                      I'm not a Maya user, but VrayEdgesTex map in Max is used for creating "fake" rounded edges through the Vray material, so I guess yes.
                      Click image for larger version  Name:	chrome_2022-06-16_12-31-47.jpg Views:	8 Size:	383.0 KB ID:	1151314
                      Thanks!
                      Aleksandar Mitov
                      96GB DDR5
                        Sorry to hear about your troubles Alex_M , ID for this issue is VGPU-5872 and the old issue is VGPU-5447
                        I added both to the GPU roadmap, I will make sure both are addressed.
                        Correct!
                        Muhammed Hamed
                        V-Ray GPU product specialist
                        chaos.com
                          Thanks, Muhammed_Hamed . I really appreciate it. Did you see my new posts in this thread? I'm still encountering the lighting bug when using very simple lighting and materials and no include/exclude lists.
                          Aleksandar Mitov
                          96GB DDR5
                            I'm following the post yes, I will reply as well
                            Muhammed Hamed
                            chaos.com
                            • #15
                              Hi Alex_M
                              This is solved, and will be part of the next Beta build
                              The older issue should get attention soon as well
                              Muhammed Hamed
                              chaos.com
