Unable to setup RTX Engine in DR
  • Unable to setup RTX Engine in DR
    Hi dear community
    I'm testing out the new vray 6 GPU and I found an issue when trying to setup the RTX engine on a slave machine.
    On the slave I have an RTX 3080 and the latest vray 60005 downloaded from nightlies.chaos.com.
    The new "select rendering devices for vray GPU" UI is pretty simple and I select RTX render engine from the drop-down menu instead CUDA (which is the default engine).
    The Log shows: "API Mode was changed to RTX" but if I close and reopen the tool, CUDA returned as if the changes were not saved.
    Does anyone experiment the same issue?
    Any advice?
    Thanks and have a great day
    AC
    Hello Alessandro.
    1. select RTX engine
    2. close program
    3. restart system
      Originally posted by Nikita2016 View Post
      Hello Alessandro.
      2. close program
      3. restart system
      I already tried, this doesn't fix the issue
      thanks
        Sorry.
        Utility "select rendering devices" only allows you to select GPU devices. It does not allow you to switch the GPU engine.
        Which software do you use? 3dmax?
          Use the code in startup
          Code:
          vr=renderers.current as string
          if ((matchPattern vr pattern:"V_Ray_GPU*")) == true do renderers.production.engine_type = 3 -- 2 CUDA / 3 RTX
