Vraybitmap failed to load dynamic map(IFL)
  • Vraybitmap failed to load dynamic map(IFL)
    Use vraybitmap to load dynamic maps. If the map file name contains Japanese, Chinese, Korean, the animation sequence will fail to load. However, it can be previewed through view img, but it is not visible in the view, Material and final rendering
    We are aware of the issue (internal bug-tracker id: VMAX-12358 ). I'll bump its priority.
      Where can I know that this problem will be fixed? I haven't been very clear where I can query the status of the tracker based on its ID
        It's an internal system (I'm posting the issue so as to link the issue to the thread report). I'll notify you whenever there is progress.
          good thank you
