2sided material in reflection
  • 2sided material in reflection
    I have a pendant, with some objects with 2 sided material, each with a sphere light inside (very typical) - on the left is a mirror wall - but you can see the reflection of the 2sided material is weird.
    Is this a gpu limitation?
    Hey AlexP
    This is not expected to happen, could you please attach your scene? or a simplified version?
    I will make sure this gets solved
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Thankyou I will save a simplified one
        Obviously in a stripped down one it works perfectly haha
        Muhammed_Hamed if there is a way I can send you the whole scene confidentially I can do that.
          Sorry for the late reply, drive should work fine
          Send it over to muhammed.hamed@chaos.com
          Best,
          Muhammed
          Muhammed Hamed
          chaos.com
