3ds max - VRayVolumeGrid - Cutter Geom
  • 3ds max - VRayVolumeGrid - Cutter Geom
    3ds max - VRayVolumeGrid - Cutter Geom: not working.
    Marcin Piotrowski
    youtube
    CGI OCIO config 04
    Hey,
    Indeed, this still has not been impelmented yet. Adding one more vote for it.
    Meanwhile as a workaround you could possibly use the V-Ray Distance texture in the Smoke opacity settings. It will be a bit slower to render, but should do the job.
    You can pick the object you wish to use as a cutter in the Distance texture and make the near and inside colors white, while the far is set to black.
    Cheers!
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      just please update the docs asap.
      I don’t mind features not being supported but at the moment with spotty GPU documentation and some of the unsupported options being greyed out in GPU UI and some not - it is simply quite a mess that seriously affects usability.
      Marcin Piotrowski
      youtube
      CGI OCIO config 04
        Indeed you're right. Will make a note to fix the docs as soon as we can so that it can reflect what is supported and what not.
        Sorry for the caused incovenience.
        Georgi Zhekov
        Chaos
          thank you. much appreciated.
          Marcin Piotrowski
          youtube
          CGI OCIO config 04
