Hi.
I have created a large Phoenix-simulation that I render with Vray GPU. (standard CPU crashes so GPU is my only choice).
All is fine for a couple of frames. Each frame takes about 5-7 min to render out. But after a couple of frames, render time increases drastically, and when at say frame 10, render takes 45 minutes, and it seems to increase even more after that.
My guess is some problem with the memory. If I stop the render, and start it again from where I left of, everything is fine again for a couple of frames, but then it repeats the same issue after a while.
How can I get rid of this issue?
