inverted normalmap with inverse UVs
  • inverted normalmap with inverse UVs
    We get inverted normalmaps with inverse UVs.
    CPU and GPU does handle this differnt. Could we get this unified.
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
    Hm, It seems only CPU in 3ds Max (Standalone CPU result is similar to GPU) displays regular normals when UVs are flipped. I'll ask the devs which behavior has to be expected.
      Thanks!
      The same is in Maya.
        Hm, it seems to happen only when there's a VRayUVWRandomizer as the mapping source for the Normal map. Is that the case on your end? If not, could you attach a simple scene?
          No just a simple file node to load the normalmap.
          Render in CPU and GPU does look different.
            Thank you. I've logged all the info (internal bug-tracker id: VMAX-12750) for developer investigation.
              Actually, in Maya CPU, there's a checkbox (Render Settings> Overrides> Textures> Uninverted normal bump) to control whether the normals get inverted or not when UVs are flipped. In GPU this option is always active.
                Thanks good to know.
