VRay GPU Error with Lightcache - Error : [MemoryManagerGpu::releaseUnmappedMemoryFromInstance] 700: Could not release device buffer
  • VRay GPU Error with Lightcache - Error : [MemoryManagerGpu::releaseUnmappedMemoryFromInstance] 700: Could not release device buffer
    Im experiencing this issue with one of my scenes. I cannot figure out what it is etc. I have switched to bruteforce and its working but this is not ideal.
    We are currently moving our scenes to Vray GPU. Any help with this?
    Vray GPU Hotfix 01 is what were on currently.
    Thanks!
    xxcvhd.fgd
    Thanks!
    Thank you for the report spencerrayfitch, I replied to your Email.
    We will get this fixed As soon as possible
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Hi Muhammed,
      We have the same issue over and over again recently and basically we can't use interactive rendering as sometimes even moving a single light can cause this issue. If this happens the GPUs are not recognized anymore and a Max restart is needed.
      I know you mentioned that it will be fixed, but is there anything we should do differently in the meantime?
      What's causing this actually? It wasn't a problem before.
      Thanks,
      David
        Originally posted by thepixon View Post
        Hi Muhammed,
        Thanks,
        David
        Sorry to hear you are having issues
        This error is about running out of GPU memory. For IPR you can swap GI to use BF, it will be helpful to keep an eye on your GPU memory usage
        If you keep LC subdivs at around 1000 it will be helpful as well
        Here are helpful tips on managing GPU memory
        If you get me a sample scene I will be able to confirm the error is about GPU memory
        Best,
        Muhammed
        Muhammed Hamed
        chaos.com
          Is "releaseUnmappedMemoryFromInstance" specific to running out of GPU memory?
          Or can it describe other circumstances?
          Best!!
          // Karl
            Best!!
            // Karl
            Hey Karl,
            It is not related to running out of GPU memory. It could be something else
            Are you able to reproduce this issue?
            And what is the error code you get with this message?
            Best,
            Muhammed
            Muhammed Hamed
            chaos.com
              Originally posted by Muhammed_Hamed View Post
              Hey Karl,
              Best,
              Muhammed
              Ok thank you! Have been away from rendering a bit. I suspect it also can be that I overclocked the first of my 2080 Ti a bit much and can be faulty GPU memory some time ago. I will check the error code. It can be reproduced. In the meantime, thank you!
                You will get 700 errors with bad OC usually
                And yeah not recommended, unless you test the OC extensively to make sure it is stable (we officially don't recommend hardware overclocking)
                Good luck!
                Best,
                Muhammed
                Muhammed Hamed
                chaos.com
