GPU building light cahe slow
  • GPU building light cahe slow
    Hi everyone, I just finished to work on a project where dimension of the shop and amount of objects, and building the light cache was very responsive and quick.
    I'm finding my self now working on a very simple scene, right now just walls of a room, a window facade and a white override material, building light chace, either in IPR or finale render takes a lot of time.
    Any know reason?
    I tried ti copy the scene in a new one but still the same.
    Would you need to check the scene?
    Lorenzo
    Hi lorenzo_spinola
    Yes please, if I reproduce this on my end I will make sure it is fixed.
    Please send the scene to muhammed.hamed@chaos.com
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Good morning Muhammed,
      just sent you the email.
      Thanks a lot.
      Lorenzo
        Thank you for the scene!
        I'm able to reproduce on my side, this seems to be related to your override material setup. I logged the issue in our system VGPU-6031
        For the time being use lower amount of LC Subdivs, it should be helpful
        Best,
        Muhammed
        Muhammed Hamed
        chaos.com
          Hi Mohammed,
          Thanks for assisting in this.
          I tried again with the scene.
          it seems to work "fine", I guess", if I switched off the object with the wrapped material applied.
          Could you check/confirm if it does the same to you? or if it's a known issue or if it's should work correctly.
          Thanks again
          Lorenzo
            Hey lorenzo_spinola
            Thank you! you are right, this is about material wrapper in your setup
            Without material wrapper I get 5 seconds for GPU LC phase​
            With material wrapper I get 19 seconds for GPU LC phase, I'm using one 3090 for this test
            I added to the ticket, thank you again and have a great day!
            Best,
            Muhammed
            Muhammed Hamed
            chaos.com
